I have a 1988 Ford thunderbird turbo coupe and I am looking for a new radiator and I thinking about getting a preformince one so does anyone have any suggestions
Huey866
Jun 2003
Catlettsburg, KY
I'm running a champion 3 core aluminium from Jegs. It's made for the Fox Mustang, but conveniently fits our cars. You'll need to clearance the battery tray a little bit and put a little extra rubber at the mounting points so it's held securely. You can get it with or without the trans cooler in the end tank.
For cooling fans, I used a 17" derale 2 speed fan, good for 2000+ CFM, and a fan shroud from ledfoot racing. Or you could just buy the whole kit from ledfoot, radiator and all.
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
RC Martin
Mar 2006
Colorado
06-04-2020, 02:08 PM
(This post was last modified: 06-04-2020, 02:09 PM by RC Martin.)
A while back I went with an HD 3-row stock replacement aluminum and kinda regret not upgrading. Stinger has a nice looking all aluminum that's thicker than mine and wouldn't have cost much more, and also a shroud with fans.
I went with a Summit branded Mustang aluminum HD radiator. Only minor mods to the mounting brackets needed. Works awesome.
vegas_ss
Jun 2005
Las Vegas, NV
06-09-2020, 04:35 AM
(This post was last modified: 06-09-2020, 04:41 AM by vegas_ss.)
I actually went to a local radiator shop and they ordered a 2 row aluminum that works real well in the 110 degree plus desert here. The size of the cores on some two row radiators are actually quite large compared to a 3 core and are only slightly thinner overall. I did put a 3 core champion in a 1991 Mark VII (same radiator as the mustang/tbird) that I got from JEGS... They usually have them on sale but you may want to call one of your local radiator shops.
The only reason I happened upon the two core was I was going to have the original radiator re-cored but they really don't do that as much anymore like back in the 80's and 90's (showing my age here). The shop owner insisted it would run the car as cool or cooler than the 3 row since it will have about the same capacity but better airflow. I did need to space the fans out a little bit, but just got longer bolts and made the spacers from some flat washers. Made about a 1/2" stack with some smaller diameter washers and ran electrical tape around the edges to hold them together... when installed it looks like a black bushing rather than a bunch of washers and works out well.
The stock tbird fans work very well, the Lincoln on the other hand would heat up a little at idle, replacing the fan clutch and fan with a 9 blade remedied that, but it would still run a bit hotter when stopped in traffic but cooled right down once moving. The tbird fans keep the temps cool regardless if moving or stopped. Don't really see any reason to swap out the stock tbird fans (unless they aren't working properly).
When I got my Bird 2 years ago I just went to AutoZone and got one around eighty bucks If I can remember. When I pulled the old one out it weigh twice as much as the new one, probably due to all the mud inside the old one. With a FMIC and AC on in West Texas heat it has never got over 95 degree C.
Whatever you do don't forget a good flush first.
