I am going to try this adapter I had made to see if its a good fix for the sagging in the rear when using SN95 springs on our birds. Spacer right now is 1", so I will test fit and cut down as necessary till I reach the right ride height. Hopefully this will make the SN95 springs more appealing.
Hey Chip, next set you make, make an extra set for me , 1 inch will work, or 3/4 too, witch ever size you make . thanks. D.Wilder........ [email protected]
let me know what I owe you , or parts if you need something .
i use a serpentine water pump pulley from a 5.0 on the top of the spring. it's 1". a v-belt pulley is 1/2". if you look close, you can see it. the spring seats nicely in the pulley.
5.0TurboCoupe1988 Wrote:i use a serpentine water pump pulley from a 5.0 on the top of the spring. it's 1". a v-belt pulley is 1/2". if you look close, you can see it. the spring seats nicely in the pulley.
What spring is that? Looks like a 5.0 lowering spring
08-03-2013, 05:52 PM (This post was last modified: 08-03-2013, 05:54 PM by 5.0TurboCoupe1988.)
RDOG Wrote:What spring is that? Looks like a 5.0 lowering spring
it is.....i also raised the front mount of the lower control arm to add anti-squat to the rear suspension giving the effect of a lift bar. that will add a little to the ride height. it sits about stock to slightly lower with that arrangement.
How did you raise the front mount? Please elaborate. Thanks
i drilled new holes about 1.25" higher in the torque box and reinforced it with battle boxes. there's plenty of room, even to use the factory control arms. i used mustang battle boxes......the hole is higher and locates where to drill.
