New Headlight lenses
MartyPA Offline
I was in pep girls and noticed a company called (I think)Cool-vue made the plastic headlamp lenses supposedly for 300 types of vehicles.Of course ours wasn't in stock.Did anyone else see these and notice if they make them for our Birds and what the cost might be?Seemed like reasonable prices for other car makes.I believe they also make corner lenses.(In the $30 range)I went to their web page but it seemed worthless since it had nothing about lenses on there.Maybe they are building the webpage.
Thunderbird88 Offline
I looked at Pep Girls (hilarious) also and was surprised ours wasn't listed. I called a Ford dealership down in South Jersey and they gave me a price of $55 for each side.
kibstone Offline
That's about what I payed... about 2 years ago...
Keith
88 TC, mostly stock. Future plans include: Eibach Front Lowering Kit; Gillis Valve; 2.5" Stainless Cat-Back Exhaust (done); T3 turbo; Ported/Polished head work; port-matching on all pieces; and the list could go on and on and on...
For every person with a spark of genius, there are a
hundred with ignition trouble.
Fox ThunderCats Offline
Ya can buy whole new housings on Ebay - a guy sells 'em for I think $150 a pair. Luckily my T-Bird had brand new headlights in it when I bought it [Image: smile.gif]
A bit of elbow grease, some fine (800-grit for first sanding, 1200 to 1600 to finish) wet sandpaper and some polishing compound will do wonders for your existing lenses...
Sam's Fox ThunderCats ... Your home on the web for fox Thunderbirds and Cougars
1owner88TC Offline
You can't beat new lense housings. Not only are the lenses clear, the reflector area is bright white again. What a difference they make! The dullness of oxidized headlights creeps up on you after a few years. I bought mine online from http://[email protected]/
fun, fun, fun - Justin
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, SPEC Stage 2 clutch, 3-core radiator.
MartyPA Offline
I called this Kool vue place up but they don't make them for T birds in our years.
Do the lenses only get fogged on the outside or do you have to sand inside somehow too?
I also get water in my headlights.About 1/2 inch at times.I'm thinking about filling them up and putting goldfish in there!
Most of the fogging is on the outside. Polishing can go a long way but nothing matches a new set of lenses. I've done both.
For the water problem the easist fix is to drill a couple small holes in the bottom of the lense
I was getting water inside of mine so I took them off and put silicone around the entire seam of the lens. If you blow inside the lens you should be able to feel where the water is getting inside.
TurboCoupe50 Offline
The silicone is a good fix, I also wrap the seam with teflon tape before the silicone cures. Daughters TC had nice clear lenses but had the mosture problem, four years later still no mosture inside. I don't reccomend drilling holes, as the reflectors will deteriate if the lamps are not sealed. Really there ain't nothing like new headlamps.
Three 1988 Turbo Coupes .....
yea one of em has a 5.0 And runs 13.1s......
uhhh make that [email protected] with a 90hp shot of nitrous.
[This message has been edited by TurboCoupe50 (edited 09-13-2003).]
1988 Turbo Coupe331 AOD
1972 Comet GT
