New head problem
RDOG Offline
I started up my new engine today and the head is making a loud ticking sound. Kind of like a rod bearing noise or the valaves are hitting the pistons. The head was majorly ported and I put a 92 Mustang roller cam in it. What do you think the problem is, or is it supposed to sound that way?
RDOG Offline
Can anyone help me [Image: frown.gif]
If it's a ticking, even loud it might be a collasped lifter. If it a real knock then maybe something got in the cylinder before the head went on. Ask me how I know this [Image: biggrin.gif]
The valves won't hit the pistons until you get into pretty high lift cams.
How long did you let it run?
RDOG Offline
I let it run for 5 minutes. I also did notice that there is a possible oil leak by the number 3 cylinder. The only reason I am saying this is because after running for 5 minutes there was a oil smell and light amount of smoke coming fom under the manifold at the #3 cylinder. But there was no oil that I could see or touch or major major smoking-just enough smoke to notice.
RDOG Offline
On another note. I did replace the springs with heavy duty springs and it has all new seals. I did not however replace the lifters, because they were fine before I removed the head to do the head work.
I wouldn't worry about the smoke yet, it's probably just spilled coolant or oil burning off.
How loud and distinct is the noise. Is it a tick or a definte knock.
Good judgement comes from bad experience, and a lot of that comes from bad judgment.
RDOG Offline
It is a constant ticking. The higher i rev it the louder it gets. It is not coming from the underside. I called Competition Heads- the one who did my headwork and he said most likely I did not run it long enough to let the lifters pump up. If this is true, how long should I run the car before I start to worry, and should it be driven or revved up?
I'm not sure how long it should take a collapsed lifter to pump up. The few I have had experience with pumped up in a matter of seconds, no more than a minute.
How about someone else on this?
I wouldn't drive the car until you know what's going on and get it fixed.
1987tc Offline
Do you still have stock length valves and rockers?
Sounds like the geomtry may be off somwhat. I have always had the HLAs pum up with in far less then a minute.
How does it run otherwise. Vacuum? Oil pressure is still good?
Wes
Sold my Turbocoupe. It went to a good home.
RDOG Offline
Vaccum and oil pressure are good. Is still has stock lifters and valves. I plan to ru it for about 30 minutes and if there is no change, I will let you guys know.
