I like this new format but was wondering if the old tech article links are still around. A lot of good stuff there for the new guys to read.
Jake
Not B Anymore
Nokesville, VA, USA
Hey Jake,
They are still here and are in the process of being imported to the forum. It's just going to take a few days, hopefully, to get it sorted out, but all of the tech articles and FAQ's will be accessible from the forum soon.
andrewjs18
Aug 2012
Philadelphia, PA
(02-17-2019, 03:14 PM)BigJake Wrote: I like this new format but was wondering if the old tech article links are still around. A lot of good stuff there for the new guys to read.
Jake
as @B said, we should have the tech articles and FAQs loaded back onto the site in the form of threads within the next few days.
Sounds great guys and Thanks !
andrewjs18
Aug 2012
Philadelphia, PA
I'm going to try to import the articles onto the forum late tonight (probably 1-2am EST)...we'll see how it goes!
Mikey97D
Jan 2018
CONNECTICUT
(02-18-2019, 10:49 PM)andrewjs18 Wrote: I'm going to try to import the articles onto the forum late tonight (probably 1-2am EST)...we'll see how it goes!
How did it go?
andrewjs18
Aug 2012
Philadelphia, PA
(02-25-2019, 04:52 PM)Mikey97D Wrote: (02-18-2019, 10:49 PM)andrewjs18 Wrote: I'm going to try to import the articles onto the forum late tonight (probably 1-2am EST)...we'll see how it goes!
How did it go?
the script just isn't going to work out...it's taking longer to try to tweak it than to just manually copy everything over since the html in the articles is so old...
for now, you can still access the articles via these links:
https://turbotbird.com/old/techinfo/techarticles.html
https://turbotbird.com/old/technical_articles/
https://turbotbird.com/old/faqs/
andrewjs18
Aug 2012
Philadelphia, PA
I've manually started copying over the articles - you can view them here: https://turbotbird.com/forum-tech-articles
It looks great !
Thanks for doing it !!
Mikey97D
Jan 2018
CONNECTICUT
(02-25-2019, 08:22 PM)andrewjs18 Wrote: (02-25-2019, 04:52 PM)Mikey97D Wrote: (02-18-2019, 10:49 PM)andrewjs18 Wrote: I'm going to try to import the articles onto the forum late tonight (probably 1-2am EST)...we'll see how it goes!
How did it go?
https://turbotbird.com/old/faqs/ Thanks Andrew!
