sscherin
May 2004
Castle Rock, Co
Has anyone tried the new Autometer Electric fuel pressure gauges?
They cost a few bucks but it would nice to put the Pressure gauge where ever I wanted.
I have had one for about 6 months. Very high quality unit, probably worth the $$ I paid for it. Sensor looks to be nearly aerospace quality, and the guage itself is much more than a simple meter movement - it is a microprocessor controlled stepper motor drive that actually runs the gauge.
The sensor fitting is 1/8" NPT, so you will need to get a 1/8" NPT female to 1/16" NPT male adaptor the attach the sender to the fuel rail.
mmedic50
May 2001
Garrett, Indiana 46738
Can you post a pic of this?
1988 TC 5 speed, Dark Blue
Build date 5/88.
140 mph Ford Motorsport Speedometer
Tripminder
Walbro 255 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
K&N Air Filter
Gillis Boost Control Valve
New rebuild- .030 over pistons.
SS valves(1.89/1.59).
Center Force Stage II clutch.
ARP head studs.
Crane roller cam .450 lift.
Gutted upper and ported lower intake.
Ceramic coated and ported E6 exhaust.
Just go to either the Jegs or Summit Racing web sites, and look up gauges. There are pics there. Looks just like any other Autometer 2 1/16" gauge. I mounted mine of the piller along with the Autometer 30 psi boost gauge. That way I can easily keep track of fuel pressure increase versus boost.
sscherin
May 2004
Castle Rock, Co
Where exactly did you put the sending unit?
On the schrader valve, port on an ajustable FPR or other?
Thanks for the input.
You remove the schraeder valve, which has a 1/16" NPT thread on the end that screws into the fuel rail.
mmedic50
May 2001
How about a part number for this gauge and sending unit? I can't find it on Summits web page.
Build date 5/88.
Tripminder
K&N Air Filter
ARP head studs.
jeffg
elyria,ohio,usa
ok i have some pics but they come out large,how would i make them smaller
86TC,85XR7,99 Mountaineer. Need for Speed
mmedic50
May 2001
This is a link to a pretty neat program to manipulate photo's, and its free. You can resize and sharpen pics pretty easy. http://www.irfanview.com/
Build date 5/88.
Tripminder
K&N Air Filter
ARP head studs.
sscherin
May 2004
Castle Rock, Co
