dezridin2
May 2004
sunland C.A.
Going to replace clutch & flywheel as soon has I get the parts from Summit. Is there any thing I should do while I have the trans out? 1988 t/c 196thou miles
zip
Dec 2006
Modesto, CA
I would do the rear main seal while i had the trans out.
Matt
Definately a rear main seal. Probably u-joints too
Either get the flywheel resurfaced, or get a new flywheel from NAPA for around $50 (the best choice). If you get the old one resurfaced, be sure to get a shim to compensate for the amount removed from the old one.
Spooler87
Jun 2003
Madison WI
Rear main is a no brainer. Its right there, and even if it isn't leaking its a good thing to do.
I would check the condition of the output shaft while you are at it...Get the driveshaft balanced and new U-joints put in too. You might as well, if it is already out.
All hail Project "Marauder" !
dezridin2
May 2004
sunland C.A.
Dont i have to drop the oil pan to get to the rear seal. Got all of the parts today. going to rebild the trans while im at it. As any one ever here ever rebilt there T-5? I did not get any gaskets with the rebuild kit. Do you need gaskets?
Quote:Dont i have to drop the oil pan to get to the rear sea
No. One way to remove it is to thread a couple screws in it, 180* apart, and then use them as leverage to walk the seal out
PetzJC
Feb 2004
California, MD
....or use a seal puller tool....
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16
PetzJC
Feb 2004
California, MD
Oh yeah, don't forget to replace the pilot bearing/bushing in the end of the crankshaft....
dezridin2
May 2004
sunland C.A.
Ok..I did not get a pilot bushing but will do so. Thanks
