There is a new article on the A4LD trans. It has some good info and a link to some knowledgible people in terms of beefing the TC version up. It under Latest Additions in the Tech Section. It was brought to us by Birdman 78758.
There is also a list of electrical grounds from the 88 documentation. I assume these should apply to the 87s and some to earlier models. It's in the FAQs under Electrical
