So I installed a new deck even though the radio and antennae didn't work, and tonight I fixed that. But I hooked up my amp to test out a set of subs I have but the amp will not turn on. The power cable and ground cable are correctly installed, but the blue accessory cable is the culprit.
My question is;
The stock stereo in my car had an equalizer, and when I hooked up the new deck I didn't use any cables from the equalizer, just from the old deck. Is there more than one blue acc. cable in the radio/equalizer harness? I'm thinking I connected the two wrong cables together.
The deck works just fine, I can still listen to music no problem.. It's just that the amp will not power on, therefor my subwoofers are recieving no power, making them not work.
Arrgh..
My question is;
Arrgh..
87 Turbo Coupe
