New adapter brackets for 7.5 and 8.8 convert drum to disc
RDOG Offline
Guys here are complete pics of these brackets installed. They are for multiple use.
1)If you have a 7.5 drum or 8.8 drum, it allows for easy conversion to 12" disc using lincoln mark seven 12" setup or 93 Cobra mustang setup
2) Allows SVO guys to step up to 12" brakes using lincoln or other. If you have drums the conversion can use lincoln setup and it moves wheels .5 inches in for allowing for a larger wheel!
3)Easy conversion for anyone wanting to take the 7.5 or 8.8 to go from drum to dics. pics shown are using 94-95 mustang axels
4) brackets are made of billet aluminum and best, hardest, and safest aluminum fro this conversion.
I think this is a great idea. what do you guys think and cost. Keep in mind that it allows you to go to your local jy and grab the brake setup from a mark VII or other ford 12" setup. No more 1000 dollar conversion necessary and easy swap. Plus it allows SVO guys to run wider wheels with no "sticking out" look or allows you dump/lower with stock size wheels-no fender rub fir stock
Comments...
Brackets
http://i158.photobucket.com/albums/t97/b...smainb.jpg
http://i158.photobucket.com/albums/t97/b...csmain.jpg
bracket step by step install
http://i158.photobucket.com/albums/t97/b...xelinb.jpg
http://i158.photobucket.com/albums/t97/b...inonly.jpg
http://i158.photobucket.com/albums/t97/b...mplete.jpg
bracket from different angles
http://i158.photobucket.com/albums/t97/b...dmainf.jpg
http://i158.photobucket.com/albums/t97/b...inside.jpg
http://i158.photobucket.com/albums/t97/b...noaxel.jpg
http://i158.photobucket.com/albums/t97/b...smaind.jpg
http://i158.photobucket.com/albums/t97/b...nfromt.jpg
http://i158.photobucket.com/albums/t97/b...rmainc.jpg
http://i158.photobucket.com/albums/t97/b...dapter.jpg
Cobra wheels installed
http://i158.photobucket.com/albums/t97/b...talled.jpg
http://i158.photobucket.com/albums/t97/b...edrear.jpg
stock 5 star wheel installed
http://i158.photobucket.com/albums/t97/b...ompare.jpg
http://i158.photobucket.com/albums/t97/b...kwheel.jpg
stock vs cobra size
http://i158.photobucket.com/albums/t97/b...dcobra.jpg
xcrunnerbd Offline
Very slick. Nice!
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
rsears Offline
Why are all the pics not available in this post?
