Need wires: 12V Ignition and Lights.
Eliminator SS Offline
Where on the drivers side of the car can I tap into a 12V ignition activated power source as well as a light switch activated source? Trying to save myself searching for them thought every harness.
1971 Camaro RS/SS, Built 355 Small Block, 426hp. Muncie 4spd. Ford 9" rear.
1979 Camaro Z28, 1974 Corvette LT1, TH350, WS6 TA Rear Axle.
1997 Mitsubishi Eclipse GST, AWD Conversion, Built 6 Bolt 4G63T, Custom FMIC, FP3065 Turbo, 579hp.
Not B Anymore Offline
The fuse box :dunno:
turbospoolin23 Offline
I have a aftermarket head unit installed so i dont need the factory EQ. I installed a few aftermarket gauges were the factory EQ use to be and found both illumination and accessory wires at the old EQ harness.
boboli Offline
Why not use the coil power to trigger a relay to then power what you want.
Tap into the wires at the headlight. If you go to the headlight relay modification in the tech articles, you will find the color of the wires for both low and high beams
Fuse 11 for the gauge lights?
boboli Wrote:Why not use the coil power to trigger a relay to then power what you want.
Thats exactly what I did.
