Need Turbo Info
cnpowell Offline
I have an Air Research that I plan to install on my TC. It has a M11 compressor section, AM4 turbine section and A/R .63. Is the the same as a Garrett T3???
Carl
Carl (cnpowell)
No TC at the moment .... planning to get another in '18
Glenn 88TC Offline
It is the same. The difference a t3 makes is very noticeable. You will like it.
You going to make the track(Cecil) this year? We need to get a few of us there for some fun some Fri. night.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, TE60 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
cnpowell Offline
Thanks for the info, Glenn. Not ready for the track yet .... I still have quite a bit of work to do. Are you ready for Monday?? Kick some SC butt!!!!!!!!!!
Carl
Carl (cnpowell)
