Ok, so I finally found the clip I needed to reattach the speedo drive gear back to the trans tailshaft. But when I took the tailshaft housing off I was stupid and removed the top cover and the shift rod to make sure all of my gears were ok while I had the trans out. Now I can't get the top plate with the shifter rod and the forks set correctly so that the trans will shift. Does anyone have a pic of how the shift forks under that plate are supposed to be set so that I can get this car back on the road.
