need tech info
cammed99 Offline
what is the technical name of the box that goes in the block that the pcv valve runs to? Mine was so corroded that when I took it out it got a good sized crack in it. Anyone know where I might find one of these or have a nice spare one they want to get rid of?
88 turbo coupe, 5 speed, stock with a gillis valve and 3 inch exhaust
4 other vehicles, all fords and all unique
89 TTA (yes the turbo one)
65 Mustang Fastback 2+2
98 GT
99 Ram 2500 4x4 Cummins on 35's
82 Bronco 4x4 FOR SALE
mmedic50 Offline
OK, I'll take the first shot at this,, I think it is called an oil separator.
1988 TC 5 speed, Dark Blue
Build date 5/88.
140 mph Ford Motorsport Speedometer
Tripminder
Walbro 255 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
K&N Air Filter
Gillis Boost Control Valve
New rebuild- .030 over pistons.
SS valves(1.89/1.59).
Center Force Stage II clutch.
ARP head studs.
Crane roller cam .450 lift.
Gutted upper and ported lower intake.
Ceramic coated and ported E6 exhaust.
Yep, oil seperator
cammed99 Offline
thanks guys, any ideas where to find one
98 GT
They are obsolete from Ford. Maybe post in the Parts Wanted forum.... I am sure some one has one from a parts car. All there is inside is a series of metal plates, so if you find a used one, all you need to do is clean it out good, and put it on.
cammed99 Offline
are these on n/a motors or is it a turbo motor specific piece?
98 GT
phyxius Offline
i had to get one for mine once so i grabed one off a 2.3 ranger from a scrap yard
