Need Information ASAP
Spooler87 Offline
Hey guys, i need some info and part numbers from you guys. I'm going to finally replace the ECT sensor and a couple of leakey Injector O-rings. Now this is what i think I'll need in parts:
Upper to lower intake gasket
O-Ring set ...?From Napa i think I heard?
Carb cleaner
Beer
ECT Sensor...wich i already have
Anything else?? Every parts store I go to says that they cannot find a upper to lower gasket, so i need a part # and price if possible I Also need the PN for the O-ring set for the injectors if anybody has it. The fuel smell is getting bad enough that i'm getting a headache from driving it. do you guys use teflon tape on the ECT?? and is there anything i should do since I have the upper intake off already?
87 Tubocoupe, Light Regatta Blue, All Options incl. Leather; 2.5" exaust, Dynamax super turbo mufflers w/3"chrome tips, MSD 6AL, Blaster2 Coil and wires, Homemade adjustable boost valve.
"May the fluids under the hoods of the beleivers flow forever"
All hail Project "Marauder" !
1. Upper to lower gasket, Felpro 92914, but I'm not sure you can order it as an individual item. May have to order an upper end gasket kit???
2 O rings. Any parts store carries them. Even Autozone would have trouble screwing this part up. GP Sorensen makes them, p/n 800-9212
How do you know it's leaking O rings and not a leaky injector?
3.carb cleaner. Try not to confuse it with 4.
4. beer. Lubricant for auto repair projects.
5. I prefer teflon goop to tape but either will work
You only need two tools in life; WD-40 and Duct tape. If it doesn't move and it should use WD-40. If it moves and it shouldn't, use Duct Tape.
[This message has been edited by Pete D (edited 12-27-2003).]
Spooler87 Offline
I Know its an o-ring because you can see a little fuel spray out when you rev the engine (with help of a friend) and it comes out right between the fuel rail snd the injector..... so I'm pretty sure its an o ring.
jabobia Offline
when i purchased my valve cover gasket kit for the XR7 yesterday, it came with the upper-to-lower intake gasket...i gave the parts guy a puzzled look since i usually just take the TB off to remove the VC, but it will come in handy since a couple hours later the oil cooler return line popped and i had to take the upper off and the lower(what a PITA) to get at it
part # : felpro vs50043r-1
all hi-temp rubber, not cork-rubber, with wire reenforcements for the bolt holes...just like the F5xx ford gasket, except $20 cheaper, and it was on the shelf at autozone...both the ford, and the linc/merc dealer would have had to order it. the felpro kit comes with the upper/lower gasket to boot [Image: biggrin.gif]
-james
www.cardomain.com/id/jabobia
jabobia.com
[This message has been edited by jabobia (edited 12-27-2003).]
jabobia.com
