Need help on electrical problem!!!!
67goingthing Offline
I pulled the dash back today to replace the heater core on my 87 Turbo Coupe. After I got everything put back togather my power windows, wipers, trunk release, and clock don't work. I crawled under the dash on both sides but could'nt find an unplugged harnass. The wipers and windows use a seperate fuse but that doesn't really matter because the fuses were ok. I'm pullin my hair out!!! Anyone have any suggestions?
Check the ignition switch connector to be sure it is on tight. All those things that arent working are fed thru terminal A1 on the ig. sw. Be sure terminal A1 has power in RUN and ACCESSORY.
