need help new bird owner
flybirdfly Offline
had the bird for a few weeks and still having some issue's with the idle or when i push in the clucth car cuts off? i took to the gas station they adjusted the idle bump the timming.and check the pvc valve and said it was good. what else could i check? i been searching the site for the last few weeks,also i notice my oil dip stick blows out sometimes and shoot oil out i thought it was the pvc valve from some of the things i've read.this is the stuff that was done to the motor by the guy i brought it from,its also has a air fuel meter that not hook up yet. i'm going to replace turbo with a holset hx40 when i find a decent wg manifold cause the t3 is smoking real bad after you get on it and let of the gas i beleave its the seals. but any help would be welcome. thanks
Bored .040 over
Head has larger valves I think they are 1.80 and 2.02
Ranger roller cam
T3 turbo
Port, polished and knifed lower intake
Gutted and polished upper intake
255lph fuel pump
bbk adjustable fuel pressure regulator
Bored .040 over
Ranger roller cam (
holset hx35/super40
255lph fuel pump
3-2.75 open dp
The Shredder Offline
Welcome to the Tbird madness! You will love this forum and the people on here. VERY helpful.
You might want to check the IAC (Idle Air Control). They sometimes get gummed up with oil. It is the solenoid looking thing on the throttle body. Make sure that works and is cleaned.
Also, make sure the dipstick sits all the way down. My TC dipstick TUBE was popping out, not just the dipstick. Check the dipstick bolt on the intake is holding the dipstick tube down. You may have a lot of crankcase pressure that is forcing the dipstick out. Check your breather assembly and PCV again.
Noticed you are in Charlotte, what part?
88TC blue/blue, auto, loaded except leather, bone stock, 127K mi. - back in the TC game!
88TC white, converted 5 spd, K&N filter, Manual Gillis BV, 189K mi. SOLD :-(
Hello and welcome. Congratulations on your new "car"
I would suggest you check the PCV youself. The PCVs for a turbo car are a little different and the avareage gas stationj is not going to know that - trust us on this one.
First check the brand. It should be "Ford P/N: E5ZZ-6A666-A (this is the correct p/n, 5/13/02) The Motorcraft box will also have EV-127-A on it" NO other PCV will work correctly and others will let boost into the crankcase and could be the cause of blowing out the dip stick.
If your PCV is the correct brand then hold it straight up and down and try to blow through the small end. If it passes any air at all it is defective. Replace it with the part above. Test the new one the same way, at the parts counter, before you buy.
Beside cleaning the IAC as menetioned above, You should probably check the engine vacuum when warm. This may tell you if you have a vacuum leak or other mechanical condition. It would be good if you pulled the codes too:
http://www.turbotbird.com/techinfo/Retri..._codes.htm
http://www.turbotbird.com/techinfo/In_Ca...rCodes.htm
Let us know what codes you get for each section of the test.
flybirdfly Offline
thanks i check the stuff this weekend. i drove her today from md, she did okay. i live in south charlotte off south tryon ang woodlawn. maybe we could hook up this weekend shredder? i also notice the ic had the two side ports block off do they need to be hook up?
Bored .040 over
Ranger roller cam (
holset hx35/super40
255lph fuel pump
3-2.75 open dp
What moron mechanic (and I use that term loosely) "bumped the idle"?? Unless you have a tuner, standalone, etc, the idle speed is NOT adjustable, unless the idiot used the base idle screw to open the throttle a little more, which 100% defeats the action of the IAC, plus will increase the TPS voltage pssibly putting it out of closed throttle acceptable range. Find another mechanic.
BTW, welcome to the board!
flybirdfly Offline
well got a chance to work on the car monday drop fpr down to 32idle under boost about 16-18psi go's up to about 48-50 i hook up the air fuel meter under boost just get into the rich side but when normal driving it jumps from lean to stioch sometimes rich. change the plugs and wire. the old plugs some were gap 29,34,28,42. after doing all this car runs 10 times better, fix the idle and when car cuts off when clucth is in. so now i need to replace the smoking
turbo. car pulls pretty hard but i dont get on it cause the smokey turbo. thanks for the help.
Bored .040 over
Ranger roller cam (
holset hx35/super40
255lph fuel pump
3-2.75 open dp
