need help gluing 87-88 taillight
88Slowbird Offline
the taillights on my 88 Bird are starting to separate and leaves and dirt are starting to get inside
anyone have a guide or know the best glue to use to put them back together?
thanks!
50RACER Offline
You need to take them apart and clean out all of the old weatherstripping and replace with same or I used black Permatex RTV. It takes about two tubes to seal it. Works great though.
87 TC Medium Canyon Red
88 TC Black Beauty
+1 on using black RTV.
04 Taurus Duratec (wifes car)
02 Pontiac Grand Prix GT
MN88TurboCoupe Offline
How do you take the lenses off without cracking them.
Publicity, fame and accolades can make a theory popular. They can't make it true.
50RACER Offline
Using a little heat may help to soften up the old sealant. If they are loose or moving at all, start at that place and just use a little steady pressure, not to harsh, to pry them loose. A heat gun, or even a hair dryer should help.
88 TC Black Beauty
I seem to remember there are a couple black metal clips (2 on the top, 2 on the bottom?) that you need to pop off. I dont remember the details as I havent restored a TC tail light is almost 20 years.
