88Slowbird
May 2019
Tampa, FL
the taillights on my 88 Bird are starting to separate and leavesĀ and dirt are starting to get inside
anyone have a guide or know the best glue to use to put them back together?
thanks!
Black 1988 TC: RR Cam (with Esslinger cam gear), Stinger FMIC, Stinger 3" Exhaust, .60/.63 SVO Turbo, Pimp V1.4, Spartan2 Wideband, Forge DP BOV
Mach 1 Red 1988 TC: All stock
50RACER
Jan 2010
Manassas, VA
You need to take them apart and clean out all of the old weatherstripping and replace with same or I used black Permatex RTV. It takes about two tubes to seal it. Works great though.
87 TC Medium Canyon Red
88 TC Black Beauty
+1 on using black RTV.
MN88TurboCoupe
Apr 2011
Minneapolis, MN
How do you take the lenses off without cracking them.
Publicity, fame and accolades can make a theory popular. They can't make it true.
50RACER
Jan 2010
Manassas, VA
Using a little heat may help to soften up the old sealant. If they are loose or moving at all, start at that place and just use a little steady pressure, not to harsh, to pry them loose. A heat gun, or even a hair dryer should help.
88 TC Black Beauty
I seem to remember there are a couple black metal clips (2 on the top, 2 on the bottom?) that you need to pop off. I dont remember the details as I havent restored a TC tail light is almost 20 years.
