DrPhang
Petersburg, Virginia,
I have done a few searches and can not find what I need.... I am going to get a 3inch DP and a high flow 3in Cat soon. I have not been to any exhaust shops yet "I have been real busy" but I wanted to know what I am gonna need to get at least 2.5 mandrel bent pipe out of the back of the car. Also which side is best to have it exit on? I am not going to get a muffler right away but I am going to run a cat so I do not get into to much trouble. I need some advice bad
Hybridbird
Aug 2001
Rockford IL
You can use a mandrel bent 2.5" tailpipe for a fox Mustang,and just have the tip extended a little.If they do it right,you won't even beable to see the part where they add on the pipe,it will be behind the quarterpanel overhang.As for between the the DP and the muffler or tail,I just had mine bent at the shop on a regular bender,the bends are just a couple of slight bend that don't make that big of a difference,I think.You will also see that when you get the DP on,that the exhaust will exit on the driver's side,it crosses over under the seats.Keep us posted.
GaryS#2
May 2001
B.C. Canada
Yah, just use the Dynomax mandrel bent TP for the left side.
If you don't run a muffler run the 3" pipe after the cat up to the TP.
You could run a cheapy 3" glasspack for a while, then get a good SS Ultraflow later.
Grocery Getter/Rice Cooker.
None2Slow
Apr 2002
Rio Linda, Ca
Or if you don't mind a little noise, not much at all, dont use a muffler. The cat will quite it down a lot.
Willing to help anybody, Anytime, anywhere....almost
85 Turbo Bird
Mar 2002
Sacramento, CA
Does Dynomax have a 3" catback for the 87-93 mustang? the PDF on their site says they only have one for a 99-01. they have 2.5" systems but no 3". Also, what setup would fit an 85 TC? The 86 GT or the 87-93 GT?
On a related topic... Does anyone know the quality of the MAC flowpath muffler in performance, sound and/or build? I was looking at getting their system but I would probably prefer the Dynomax setup if they have the 3" system that fits.
85 TC Auto
250-280 rwhp or Bust!!!!
mods: Sony HU, Pioneer 6.5" 3-way in the door and Pioneer 6x8 2-way in the rear deck; full 3" exhaust on the way (dp, hi-flow cat, straight through muffler) (the first 2/3 of which is now in my living room!!)
85 TC Auto
mods: Sony HU, Pioneer 6.5" 3-way in the door and Pioneer 6x8 2-way in the rear deck; full 3" exhaust installed(dp, hi-flow cat, 3" MAC mustang GT cat-back)
Chuck W
Indpls, IN,USA
Check out the "yet another muffler" post as well
I don't know what your problem is, but I'll bet it's hard to pronounce.
Nate K
Eastern Shore of Virginia
Stay away from MAC's stuff, they are crap, rarely does any of their stuff fit right. You can check out several of the Mustang UBB's for the same opinions.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
