[size:11pt]Problem: My high beams are out.[/size]
Car Info:
87 with Auto Dim. Relays installed for Lows, Highs and Fogs with fuses and good grounds. Just did the 130A Alternator upgrade last night. (WHICH IS AWESOME!)
The relays have been done for a while. There is fuses in them. This happened after the 130A Alternator upgrade from last night. All three relays are wired the same and I am not having issues with the low or fogs.
RESEARCH:
I did a search and after some additional trouble shooting from those posts nothing fixed it. I eventually found out why they weren't working.
I keep blowing the lamps out.
When I figured out they were burnt and went to store and replaced them and blew them in front of the store worker while testing them. They flickered on and burnt out.
Graciously the parts store(O'Reilly's) warrantied the bulbs I paid $40 for and At the moment I am stumped. I dis-connected the relay so I can't burn $40 at the flick of a switch again.(Sylvania bulbs).
I don't have any wiring diagrams of the lights. How is too much juice going to lights to blow them and not blowing the fuse? I read that the lights are grounded as well?
Car Info:
RESEARCH:
1987 5 sp.
- 4.6 2v swap.
- 4.6 2v swap.
