Need ABS schematics
[email protected] Offline
In my previous post (Now nevermind) I was needing the fuse block schematic. I found my Haynes manual, so I have that covered.
Now I really need the ABS Power Relay schematic (Green Relay, may have been a tan relay at some point, either way its NOT the Grey pressure pump relay). When I turn the Key on, I only get 1.78 volts to the relays coil (The + side of the smaller wires). If I jumper the bigger wires the system fires up. For whatever reason the relay isn't getting proper voltage to be activated, where does it go if traced back from there? I would assume the Ignition switch. Any fuses or fuse links involved?
Schematics of the ABS computer and its associated wiring would be appreciated, if not just tell me where this relay gets its switched 12V+ source from. All I could find on this site was the diagrams for the pressure pump relay (The Grey one), which is functioning perfectly.
1987 White TC 5spd will be for sale shortly. 185K + miles, Daily Driver. http://hometown.aol.com/fhpstang1
Pete D2 Offline
What's your email?
Turbo
[email protected]
