DAN2.3
Feb 2009
Lacolle,Quebec
Went to Napierville Dragway last week-end. I did a new personal record with my bone stock 87 automatic t-bird. 14.21 at 94mph with 1.91 60ft.
My engine was bogging a bit before the finish line, so as soon as it's fix i'll go back to see what it does.
http://www.youtube.com/watch?v=JJl6G89qUQU
Medium Budget Dan!
87 TC,stock long block with a237 cam,Stinger 3 inch exhaust and PIMP,svo T3,75# injectors,top mount intercooler with bov,3500 stall with c4,Hoosier slicks and skinnies.
Redbone
Apr 2009
Ashland, MO
Is that 1/4 mile or 1000' ft? I have a hard time seeing a bone stock auto TC running low 14's.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
DAN2.3
Feb 2009
Lacolle,Quebec
That's 1/4 mile.And video will follow in the next few day's. The little .48 ihi is spinning to the max.I'm pretty sure after i fix the bog it will see very low 14's.
Medium Budget Dan!
1988turbotbird
Feb 2007
Carlisle, Pennsylvania
Definatly post a link to that video ha
DAN2.3
Feb 2009
Lacolle,Quebec
Medium Budget Dan!
DAN2.3
Feb 2009
Lacolle,Quebec
Im gonna put the video tonight with a picture of the engine bay....
Medium Budget Dan!
AllAboutCars101
Jul 2009
suffolk, VA
i dont think ive ever seen any bone stock car lifting that much off the line, even on slicks. i have a full stinger 3in exhaust on my car and it doesnt feel like i could run a 15.5
im not sure how you did it, or if you bought it from someone who has done some head porting and mild cam job and u just havent looked at it
if you honestly did run that time with a stock car let us know the details on how u did it, it would be a mojr break for the 2.3T world.
tr_guy79
Jan 2004
SE PA (DELCO), USA
If your IHI is spinning to the max, the car ISNT bone stock unless you have a faulty BCS or faulty wastegate actuator. BONE STOCK means as it left the factory (minus your indicated lack of PS, swaybars and use of slicks).
This would require roughly 292hp at the crank assuming the car weighs in around 3500lbs at the tree (which should be pretty darn close with driver and fuel minus 25 lbs for lack of swaybars). This is assuming a 17% drivetrain loss.
This would mean you car would need to be making 147hp MORE than stock, which was only 145hp to begin with, without any mods.
Call me skeptical, but this just doesnt add up in my eyes...
Is this the same "bone stock" TC that we are talking about in this thread?
http://natomessageboard.com/cgi-bin/ulti...p=1#000000
bang4thebuck
Jul 2004
pennsville NJ
Modified trans with shift kit
2.5" exhaust without cat and doudle muffler
timing at 12* with knock sensor unplugged
hoosier 26x9
cobra aluminum skinnies on front
removed sway bar (front and back)
removed egr (boost gauge plug in the hole)
modified snubber on the back (1" to the diff)
removed quadra shock
No power steering, no binder,no a/c
MYTH BUSTED!
