Ok, throwing this one out for general consumption in case someone has some ideas on it.
I have had a mysterious noise for about a year now. Have tried to trace it but without success. If you are going down the road with the window open on the drivers side it sounds like it is coming out from underneath the left side of the car. It is more or less of a rattling sound but very loud and very definite. Just last week, I pulled into the driveway and the sound was very loud. This was with the clutch out. With the clutch depressed, the sound went away (aha!) The clutch disc, pressure plate, throwout bearing and clutch fork were replaced with all new parts about a year age. The clutch, pressure plate, and throwout bearing is a Centerforce Stage II. The clutch fork is a Ford item. The pilot bearing was also replaced and the rear main seal was also. The flywheel was also resurfaced. As a side item, the cover on the catalytic cover is not loose or rusted either. Ok, that's about it. Anybody got any ideas on this?
Thanks In Advance,
Gary
NATO Member
1987 Turbocoupe
150,000 Miles
5 Speed
Black w/Raven Interior
Gillis Valve
3" Downpipe
Dynomax Super Turbo Mufflers w/2 1/2" exhaust
Centerforce I Clutch and Pressure Plate
Polished upper intake, lower intake, throttle body, front of turbo, water pump, tensioner pulleys, IAC, EGR, fuel rail. Chromed valve cover, top radiator cover, radiator brackets, alternator, air filter top, top of fan support, wheel centers, intercooler and bracket (all courtesy of Dan Eaves Polishing Services, Tuff Stuff Performance, and J&P Plating)
http://www.turbotbird.com/showroom/gs_87tc.com
Thanks In Advance,
Gary
NATO Member
1987 Turbocoupe
150,000 Miles
5 Speed
Gillis Valve
3" Downpipe
NATO Member
1987 Turbocoupe
168,000 Miles
5 Speed
http://www.turbotbird.com/showroom/data_...t_87tc.php
1987 Turbocoupe
168,000 Miles
5 Speed
