Mysterious Noise
Gary S Offline
Ok, throwing this one out for general consumption in case someone has some ideas on it.
I have had a mysterious noise for about a year now. Have tried to trace it but without success. If you are going down the road with the window open on the drivers side it sounds like it is coming out from underneath the left side of the car. It is more or less of a rattling sound but very loud and very definite. Just last week, I pulled into the driveway and the sound was very loud. This was with the clutch out. With the clutch depressed, the sound went away (aha!) The clutch disc, pressure plate, throwout bearing and clutch fork were replaced with all new parts about a year age. The clutch, pressure plate, and throwout bearing is a Centerforce Stage II. The clutch fork is a Ford item. The pilot bearing was also replaced and the rear main seal was also. The flywheel was also resurfaced. As a side item, the cover on the catalytic cover is not loose or rusted either. Ok, that's about it. Anybody got any ideas on this?
Thanks In Advance,
Gary
1987 Turbocoupe
150,000 Miles
5 Speed
Black w/Raven Interior
Gillis Valve
3" Downpipe
Dynomax Super Turbo Mufflers w/2 1/2" exhaust
Centerforce I Clutch and Pressure Plate
Polished upper intake, lower intake, throttle body, front of turbo, water pump, tensioner pulleys, IAC, EGR, fuel rail. Chromed valve cover, top radiator cover, radiator brackets, alternator, air filter top, top of fan support, wheel centers, intercooler and bracket (all courtesy of Dan Eaves Polishing Services, Tuff Stuff Performance, and J&P Plating)
http://www.turbotbird.com/showroom/gs_87tc.com
1987 Turbocoupe
168,000 Miles
5 Speed
http://www.turbotbird.com/showroom/data_...t_87tc.php
Gary S Offline
No ideas anyone?
1987 Turbocoupe
168,000 Miles
5 Speed
Mr.T Offline
A thought is the parking brake cable. It is supposed to have a rubber/foam donut on it so that it does not rattle against the floor pan. That may be missing. Might have been knocked off during the clutch work. Just an idea.
1985 T-bird TC, 5Spd, Black (The Project)
1985 T-bird TC, 5Spd, Black (The Project II)
1986 T-bird TC, 5Spd, Black (The Show Car)
1986 T-bird TC, 5Spd, Silver (The Daily Driver)
1989 Mustang GT, 5Spd, Black
1986 T-bird TC, 5Spd, Black (The Project Car)
Dan S Offline
Gary,
Before I replaced my clutch a few months ago, there was a rattle similar to what you described. The flywheel had been resurfaced, but whoever cut it, took a little too much bite. As the clutch wore the noise got worse, then one day it started to slip. When we replaced the clutch, the face was far from worn out, but the springs were making contact with the flywheel, thus the slip and the noise.
Dan S
84 and 88 Turbo Coupes
It's no longer a hobby, now it's an osbession!
Dan S
1972 Ford F-100 SWB Styleside
2015 Lincoln MKC 2.3 EcoBoost AWD
BJL Offline
Moderator
make sure that your throw out bearing is level with teh fork, mien isnt it crocked os it make s very slight niose, and also i have a internal trans niose, it sounds liek a nock, but a less of the nise coudl eb what you describe.
also checl the cluthc fork cover, they tend to get loose.
if you wondering, i have ablown trans mission, blown turbo, and a greta motor til i hit 3000rpm, and she stil going, yeah! , sorry, i just feel special, lol. NOT!
Brian J Larkin
1988 Turbo Coupe 5spd
Twilight Blue (looks like midnight blue)
gillis boost valve, k&n cone, 3.73 gears,mild torquie cam
factory DP,high flow 2 1/2 cat, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
she's a junkyard resurection. running $100 dollar used motor, know having some serious boost and bucking issues, but im thankful its running agian http://natomessageboard.com/uploads/BJL/burnout3-9.jpg
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
