birdsancoins
Jan 2004
Boyce,Va
My 88TC is runnin like crap.2.3 5spd.New wires,new O2,new egr.When stomped on car falls on its face, but keeps running.Seems to be turbo related.When turbo is engaged,firm ride light comes on.Codes come back as 28,67,81.This is with KOEO test.Car seems to change RPM whenever anything electrical is used. ?????? HELP
onedoobie
Mar 2004
roxboro,nc,usa
ummm,try to check all your majar grounds from bat to block and from block to car,and also changed the fuel filter lately?that is a great mod that worked for me..hope i this helps. -doobie
28 = VAT sensor voltagr out of self test spec. Was it less than 50 * F ambient air temp when you pulled the codes. If so don't worry about it. If warmer than 50, could be a probelm w/ the VAT
67 = did you by any chance have the A/C or the defrost or partial defrost setting on when you did the test? If not then there is a list of possibilities, let us know.
81 = electro drive fan circuit failure. or IAC circuit failure or boost control solenoid circuit failure.
Do you have the factory BCS unplugged electrically?
What wres? what plugs?
Firm light will come on at over 3/4 throttle, which is probably what you are seeing.
Check fuel presure under load to be sure it is base (39 psi stock) plus boost. If fuel pressure cant keep up under boost, car will run like crap, and bog under boost.
birdsancoins
Jan 2004
Boyce,Va
Pete, The temp out side was 70,and the a/c was off as well as the defrost.New fuel filter last month.I put orig equipt plugs and wires.What is factory BCS? What do i need to check fuel pressure?
BCS: black solenoid mounted to inner fender near VAF. 2 vac lines, one electrical connector. Allows EEC to adjust boost between 10 and 15 psi.
You need a fuel pressure gauge with a long enough hose so you can tape it to the windshield and see it when driving. Attaches to schraeder valve on fuel rail. About $40 at most parts stores, and worth every penny when trying to diagnose drivability problems.
