My friend wants to up the boost on his 88 TC, what fitting needs to be drilled?
sctur601 Offline
Thanks guys, What fitting is it, and what size is good to get 18psi?
Thanks again
Shawn
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
And it still feels slow!
Thanks
Shawn
Please click the link if you want to sign my aftermarket head list
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
I also do port work, if you need something ported email me at [email protected]
Chuck W Offline
It's the "t" fitting on the turbo outlet housing. You have two hoses, one runs to the turbo inlet and the other to the BCS which then runs to the wastegate. The one that runs into the turbo inlet is the bleed orifice. Actually on his car, if your just remove the BCS and run the hose directly from the turbo outlet to the turbo inlet fitting he should see 18-19 psi. No drilling required.
Chuck
The Cat in the birdcage...
sctur601 Offline
We allready removed the BCS but boost is only about 16psi. He wants to try a little more boost but dont want to go too far.
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
