turbochick
May 2007
great falls, mt
So i was driving my '87 to work yesterday and I wanted to turn my new stereo on. well it wouldnt turn on when my headlights were on. After i turned off the headlights and flipped them back on, my stereo worked but the lights in my dash went out.. I dont know if I have to replace a light in there or not.. I dont even know where the fuses are..lol. Any help would be greatly appreciated.
MMMMMMMMMMMMMM...turbo!!!!
Joe F
Jul 2002
Hawkins, Texas - USA
Fuse panel is located to the door side of the steering column under the dash; real PITA to get to.
Did you have the stereo installed somewhere? If so, I suggest taking it back to them and have them look at / fix it, it sounds like it may have an install problem.
Otherwise it could be just coincidental occurences, and perhaps the ignition switch needs replacement; a defective one can cause some pretty strange symptoms to manifest.
HTH
turbochick
May 2007
great falls, mt
we installed the stereo ourselves. will check the fuses after my fiance gets back from work
