My Clutch is in !!! (long and Dial-Up beware)
Dan E Offline
Here are some pictures of my new flywheel and SPEC Clutch installed.
Also a pic of my freshly re-painted tranny before I re-installed it. I never found a tranny jack that I liked so I built my own cradle for my floor jack that worked OK.
Thanks to Scott Ressler for the SPEC Clutch ! Well packaged with P/P (Stage III), Disk (Stage II), T/O Bearing and Pilot Bearing.
Thanks to Pete for the new Fork.
Flywheel is from NAPA.
I also changed the rear main seal while I was there.
Only have 380 Miles left until it's broken in...and it's difficult to not get into it...since it was down for a while but I'll be patient [Image: rolleyes.gif]
Noticeable better shifting, however I also noticed that the clutch pedal seems much "softer".
The clutch doesn't engage until the pedal is almost fully released ? Fluid level is fine. Do you think I need to bleed the Slave Cylinder or is it just a new feel or will this change in time ?
Anyhow, I'm driving my TC again.
Now to the driver's window off the clips, the heater core (that will WAIT), the sticking HLA, the broken fuel gauge sending unit, the....... Ain't TC's fun !
Dan Eaves
88TC 5spd, Crower 5.5" Sportsman Rods, Short Wiseco Pistons bored .030" Over, Ported Head with Polished C. Chambers, Gutted&Polished Upper, Ported&Polished Lower, Polished T/B, Ported E6, SVO T3 .63AR Turbo, Forge BPV, 3" DP w/No Cat, 2 1/2" DynoMax single cat back w/DynoMax Super Turbo Muffler, RR Cam, K&N in Nose, Gillis Boost Valve, Spec Stage II Clutch Stage III P/P, Removed A/C, Polished Wheels, Polished Valve Cover, Polished Crank and W/P Pulleys, Walbro 255LPH HP Pump.
[This message has been edited by Dan E (edited 04-20-2005).]
Dan Eaves
Looks good.
How about some details on the construction of the trans jack!
Dan E Offline
I'll take some more pictures of it and post.
Pete, any ideas about the "feel" and engagement of my clutch pedal ?
Dan Eaves
Joe F Offline
Dan, as I recall that's exactly how mine felt when I first put it in: somehow "softer" than the stock clutch, and at the sme time much more stickey; it took a while to get used to it.
Sorry but I don't remember where/when it engaged.
HTH.
Joe F.
JR's Place - My 87 TC
Dan,
If you didn't open the hydraulic system, then I doubt that has anything to do with feel or engagement point.
I can't speak to the Spec stuff specifically, but I have noticed that people with the stage II -III stuff, either Centerforce or Spec don't complaing about heavier feel. I don't know if that is due to the hydraulic system or some new technology that allows greater clamping force yet less leg work
As for engagement point, it seems that the thicker the FW the higher the engagement
point. I would suspect it will change a little as the clutch wears in and seats.
Drive and enjoy!
[This message has been edited by Pete D (edited 04-21-2005).]
Ryan H Offline
I installed a NAPA flywheel and SPEC Stage III and noticed no difference at all in the clutch engagement/pressure.
My friend's '94 Bronco 5.0 has a hydraulic clutch and the pedal got soft, so I checked the fluid and nothing was in the resevoir, so we refilled and bled it and it restored the pedal. Just food for thought.
Ryan Harris
1988 TC 5 speed, all options including sunroof, SPEC Stage III. Currently installing: Walbro 255 LPH HP, Kirban AFPR, 3" DP to 2.5" duals, bypassed cat, Magnaflow mufflers Smile
tps87turbo Offline
Damm that Tranny looks nice Dan. I think the clutch engagement could be either the break-in of the clutch disk or the flywheel may have been cut & required shims to bring it up to spec. I thought the Napa Flywheels were Ford original ones that were resurfaced, but I could be wrong.
Tony Sceia -
HIS Red 88 TC
GlassRooster Offline
The Flywheel I got from AutoZone for 45 bucks was a resurfaced Ford from Standard Flywheel
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
Glenn 88TC Offline
Mine grabs very high also and is soft compared to the centerforce I had in it. It grabs like hell though.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
Dan E Offline
FWIW...the flywheel is new not reconditioned and surfaced.
Also I gave Pete the thickness of the new one versus my old one. I forget exactly what they were now but it was only 1/32" thicker than my old one.
Dan Eaves
