My bird is cooked
Chano Offline
Well the bird is dead. been though everything i can possibly think of and the only thing i am sure of is there is a bunch of crap down in the oil pump from the 2 distributor gears that have been chewed up in the last week.
Can anyone recommend a good rebuild kit? I was looking at this one from flatlander racing.
1038T-HP Ford 140 2.3
1983-89 3.779 Stocking or custom forged pistons in any compression, rod or stroke w/moly rings, Fel-Pro gaskets, main, rod & cam bearings, brass freeze plugs, High Volume oil pump, lifters, timing set, performance wrist pins (no cam)
Its pricey but good quality parts. My cam has some mild wear but nothing i am worried about. I found another motor in a junk yard that is going to be my core for 200 bucks. This is going to be my first rebuild is there anything else i am going to need that i am overlooking? Going to take me about 6 months to get the money around for it so i have plenty of time.
88 t-bird turbo, 5 speed manual
boosted chicken Offline
Have the bores and crank checked first before ordering anything to make sure you order the correct size pistons and bearings.
For that matter, you could drop the pan on the junkyard motor and if there isn't any garbage in the pan and the rotating assy spins ok, just use that shortblock with a new oil pump.
Don't use a high vol or hi pressure oil pump or you will likely have more chewed gears to deal with. Use the stock pump. The hi vol hi pressure pumps put too much strain on the pump shaft. There are plenty of past posts on this issue
Chano Offline
Thanks guys. Going to be a learning experience.
