svo_thunderchicken
Jul 2005
Kingsport, TN.
What will i need to use 85 mustang svo rear disc caliper brackets in otder to add rear disc on my TC? it as simple as geting 87\88 rotors and svo calipers?
Turbojet
Feb 2002
Connellsville, Pa. USA
SVO's and TC's have different rear brakes. The SVO brakes are bigger than the TC. If you have everything from the SVO just put everything on/swap rear ends. The 85' SVO has 3.73 gears yours will have 3.45's. I am hoping that the SVO is non-repairable.
The Family:
86
87
88
svo_thunderchicken
Jul 2005
Kingsport, TN.
i dont have the rear end, just the brackets and hardware taht bolts to the axle, i was wandering it i can use it... is there a 4 lug rotor that is compatible with the svo brackets and calipers?
Chuck W
Indpls, IN,USA
No..no 4 lug compatible with the SVO brackets/calipers.
The SVO axles are longer than the TC ones...and it reflected in the brackets..so unless you mod the brackets, you will not be able to make use of them as things just will not fit together.
83 TC Clone, 84 XR7, 80 XR7, 80 Zephyr Z-7 (pending), 86 XR4 AND 88 Scorpio
