Mustang Control Arms?
unseenturbobird Offline
I know this an an extremely common question. I used the search function and couldn't get a straight forward answer.
Next weekend i will be rebuilding the entire suspension on my 88' T-Coupe using mustang struts/shocks/springs with the required rear adjustable control arms. I'm looking to get this done in one shot and not have to touch it for awhile so i spent some good money on quality performance suspension components for our cars.
I'd like to upgrade the front lower control arms to tubular. Ofcourse they don't sell any for the T-Coupe specifically. However after using search i know that the 94-95 mustang control arms are the same.
This is where i get confused, will i be able to use the 94-95 control arms without modification on my 88'? I seen on a few threads that the balljoints are different. Or does this only apply to earlier year T-Coupes?
Thanks in advance!
88turbobird5 Offline
Following
88 T-bird stinger fmic/cold air intake/t3t4/stinger oil feed line/3 inch full exhaust to dauls/super coupe throttle body
BJL Offline
Moderator
yes 94-04 mustang control are the same as the tbird. only thing different is the ball joint.
if using a 94-04 mustang spindle the mustang ball joint is the correct match.
im using mustang control arms in my 88. i have swap over to 5 lug using 94 mustang spindles.
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
