Muffler help
88BirdOfPrey Offline
Ok, the person who sold me my 87 had Flowmaster muffers on. My car feels like it's straining after around 5000 rpm.
Should I have a muffler shop just remove the mufflers and put straight pipes instead? I can get it done for 70. Would it be too loud? Is it worth doing? I live in California.
Or should I just wait and get the Strick9 exhaust kit? It'll cost me about 435 with muffler and cat. That'll take me about 2 months to get.
Please help, thanks!
Mike
GaryS#2 Offline
Flow 40 or 50?
Does'nt matter anyway, especially if you have IHI turbo still.
2 flows would flow more than enough air than your engine is capable of pumping out.
Grocery Getter/Rice Cooker.
Not sure which. I thought that Flowmasters weren't as good for these turbos? Either way, how would a straight pipe replacement sound?
Glenn 88TC Offline
I really don't think the change would be worth it till you can do the whole exhaust. Just wait and do it right all at once.
88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
Coming very soon(ordered and on the way) SDS, 73pph injectors, custom roller cam
NO TC and NO headaches.
Ok, thanks for the help! I'll just wait for the exhaust system then.
