Hi Everyone,
I got 2 issues
1. I had tip installed on my muffler a few years back, problem is they heated the pipes and ment them downward, the weight of the tips makes them easy to bend, and well one of them broke off about 6 inches away from the tip weld. If I have them re-weld the tip it might be shorter than the other, that would look stupid. I would like to know if i could just replace the pipe from the resenator (replaced mufflers) or any other options would be helpful.
2. What controls the sentry system to turn off when it reaches its desired temp. Right now (after we replaced the heater core) the heat blows fine, theres just no way to control it. Entire A/C system has been removed as well.
I got 2 issues
