Motorcraft Throttle Position Sensor TPS CX1018
RC Martin Offline
For $15 on closeout at Rockauto right now!
maweesmusclecar Offline
Hi RC,
I have been looking for one and JC Whitney had this one as a true fit, but when I talked to SAles guy, he said that one ios for the 5.0.
Pete Dunham gave me the Ford # today, but I already found one at B&B in Bronx, NY. They have a warehouse full of discontinued Tbird parts and most all other discontinued Ford vehicle parts.
You might want to check them out.
Cindy Abel
88 2.3
glenn-tc88 Offline
what is the ford part number? what year is it for?
Glenn Dembowski
2003 Mercury Marauder Black
1988 Thunderbird TC Sandalwood 5sp
1974 Harley Davidson FLH
1998 Chevrolet K1500
RC Martin Offline
83/84, might fit others. Still on Rockauto for $15.
Although I have ran into one before, another Motorcraft, that was the same TPS but had a differently shaped connector.
glenn-tc88 Offline
cx1018 shows 83-84 anybody have the 88 part number? been waiting
Glenn Dembowski
86 XR7 5spd Offline
rockauto lists both the 1016 & 1018 for 87 Tcoupe, so yup it's a bit unclear...
I'm guessing it's the 1018 since it lists the merkur as an interchange, which would be 2.3 t only ?
maybe this will help ?
http://www.walkerproducts.com/_pdf/12d-t...sguide.pdf
couple years back I bought the 'wrong' TPS thru rockauto (for my 86) - I think it was an N/A version;
then went back and got the 'right' one
I'll dig thru my receipts and see if I can find it
David T
T5 / ported E3 / .63 / 35# / K&N
2.5" exhaust w/ cherry bomb
30+ mpg! 8.2 0-60, 16.4@88 1/4 (gTech)
86 XR7 5spd Offline
ok the one that didnt work was Tomco 14033 (note does not list merkur in interchange)
claims OE part # E53F-9B989BA, E63F-DA, E8DE-AA, E8DF-AA, D8FF-AA FUEL INJ
the one that was correct was standard motor products TH16 (note does list merkur in interchange)
claims OE part # E5ZF9B989AA, E5ZF9B989CA, E5ZZ9B989A, E5ZZ9B989C, E6ZF9B989AA, E6ZF9B989AB, E6ZZ9B989A, E7ZF9B989CA, E7ZZ9B989C
sorry this is somewhat anecdotal but I hope it helps
David T
glenn-tc88 Offline
86 XR7 5spd Wrote:ok the one that didnt work was Tomco 14033 (note does not list merkur in interchange)
thank you david.
Glenn Dembowski
