motor to tranny....
Joey Hager Offline
im putting the motor out of my wrecked thunderbird into my other one... and I have done this a couple but I also have a little bit of problems getting the tranny and motor lined up.. the car is a 5-speed... the problem is the getting the input shaft into the clutch and the engine... has anyone got any tips to make it a little easier????
just wonderin.
thanks... Joey
88 turbo coupe, black 5-speed all options but leather, K&N cone, 3 in. downpipe, no converter into 2.5 in. one chambered flowmasters, 86' GT stainless tips, gillis boost contoller, 3.73s, 16x8 (knightrider) rims, 2 JL audio 15s in trunk, punch 800
Cut the front yoke off a driveshaft and use that to turn the output shaft so that the input shaft turns and meshes through the spline teeth in the clutch plate.
DennySweet Offline
An clutch alienment tool!
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
gddevil1 Offline
Sometimes it helps to get the trany bolted up and close (the bolts pulled up until about a half inch from tight) and have someone slowly push the clutch pedal in as you work the tranny up to the motor. A clutch alignment tool can help, but sometimes it dosn't quite line up the clutch disk.
1988 tc-
3" atr downpipe
2.5" atr duals
k&n cone
all else stock..
for now
1988 tc-
3" atr downpipe
2.5" atr duals
k&n cone
Gillist Boost valve
centerforce clutch
3G alt. from Pa- performance
all else stock..
for now
NATO member
A broom handle can be used as a clutch alignment tool. Do not use the trans to bell housing bolts to force the tranny up to the bell housing. It OK to use the bolts to hold the tranny in place once you get close but don't use them to close the gap until you are sure the splines on input shaft are through the clutch disk.
gddevil1 Offline
sorry, I left out info -- yes DO NOT tighten the bolts up agaist the bell housing. I meant only for them to be holding the tranny in place. They should be within .75' -.5' when the input shaft is lined up in the splines of the clutch disk. The tricky part seems to be getting the tip of the input shaft into the pilot bearing (close tolerances). if you have the clutch disk on the input shaft and release the pressure plate's hold, then you can line up the pilot bearing and push the tranny up into place where it can be bolted up tight. I am not as experienced at giving advice as Pete D. is [Image: smile.gif]
1988 tc-
3" atr downpipe
2.5" atr duals
k&n cone
all else stock..
for now
1988 tc-
3" atr downpipe
2.5" atr duals
k&n cone
Gillist Boost valve
centerforce clutch
all else stock..
for now
NATO member
