Motor mounts
Harvs Offline
I searched for them, but i couldn't get the right info. Do they sell urithane mounts for the 2.3?
Sandlewood beige 88 coupe 93k/ super 60 T3 at 24 pounds/ ATR 3" no cat or tail pipe/ 255lph high pressure pump/ Kirban AFPR at 42/ Spec stg3/ GN FMIC/ Blitz BOV/ 14* timing/ disconected KS/ Tri-ax short throw/ Autometer boost,vac and air to fuel/ 140 spedo/ Ford motorsports 5300-c springs/ tubular rear upper cntrl arms.
Get hold of Chuck Warren (Chuck W). He ran off a small volume of custom made poly motor mounts. Maybe he has some left, or will do another run if the demand is there. AFAIK, no "regular" manufacturer makes poly mounts.
mh23turbocoupe Offline
just bought a left side for mine part number 2661 in just about any type of mount crossed to that number sealed power also makes a set they are larger in diameter but work fine
87 TURBOCOUPE some mods 92 ranger
