Motor Buildup Headway Update
**PathogeN** Offline
Well since the block currently in the bird is shot (nearly a 1/4" deep gash in bore) i decided to build up my original motor (225K miles) as a temporary solution at very least since I'm tired of taking the bus and the bike. Anyway, tore it apart and had it checked out and get this..less than 2/1000ths variation from spec on bores and less than 1/1000th on the pistons. No ridge at all. Current plan (since I am beyond tapped dry) is to basically tank it all, do the bearings and rings and throw the mofo back together. Had planned to to a bore but I don't really need to so why spend the money? Anyway theres the update on the deadbird for you guys. Just goes to show what this motor can take if maintained well!
[This message has been edited by **PathogeN** (edited 12-06-2001).]
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
bigred Offline
Just pulled the head off my Bird with 132,000 miles and the bores are still within the factory bore specs and only vary from 3.7799 to 3.7815
1988 TC T-5 swap,New Head,Wiseco .030 pistons ,5.5 Crower rods ,balanced ,24x12x3 intercooler,T-3 .60
Ranger Roller Cam,New brown tops.
New 3"cat and 3"single SS exhaust
