More stupid bird tricks (Timing?)
**PathogeN** Offline
I was drivin my bird around the other night (was running perfectly) and all of a sudden (i just downshifted to come to a stop) it started to run really bad...like it does when I blow up an intercooler hose or something. I limped home (still went like 40 but not easily) and figured it was a hose. Well it wasn't and I could find nothing wrong at all. I then guessed, well maybe the timing skipped or something. So I line up the cam mark and sure enough, TDC. I then start the car and it runs fine. (All i did was turn the crank around). Today, it did the same thing again (runnin bad) but this time when I got on it from a stop. And sure enough, turning the crank around fixed it again. Any ideas? Is something loose that I'm tightning when i turn it or what?
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
Sounds like the cam timing belt is jumping at higher stress levels like fast starts and downshifts. Either you need a new belt or maybe also a new belt tensioner.
and jack rails.
Thanks. The belt appeared to be a bit loose. I have a nice ets tensioner laying around here so I guess now's a good time to put it on. How much play is "OK"? The belt now appears to be pretty loose....i can push it back about 1/4 inch or so. Probably way too much.
One of my tensioners likes to hang up when "released" to reapply tension. I use a crowbar to give it a little nudge. It can only go so far so you don't need to put a lot of force on it.
and jack rails.
