I have been researching good ways to lower the 88 TC about an inch and have read all of the discussions about SN95 springs. I picked up some 04 GT convertible springs both front and rears and installed them on the 88. The fronts I had to cut half a coil to get it to sit right, easy enough. The rears I had to use a 3/4" spacer to make up for the shorter springs, it sat right at 26" to the fender well, perfect. But, the SN95 rear springs are way to low of a load rating for our cars and it felt like bottoming out on every little bump or dip in the road. I was not satisfied with them so after some research I found that Moog makes some coils for the old Granada and LTD line from the 70's and 80's, Same dimensions, same mounting, but have a higher load rating and spring rate, plus they have a 1" lower installed height compared to the stock TC rears. I bought a set off the Bay for $46 brand new in the box and just installed them last night along with some Koni orange shocks. These are installed with no spacers, isolators, or cuts on the spring, sits right at 26" to the fender well. Took it for a ride and no bottoming out. Thought I would pass along the info as I know many on here want to lower theirs as well. I am keeping these installed. So to cap, fronts are stock 04 GT convertible springs, cut half coil and no isos, rears are new Moog CC821's not cut, no isos.
