Huey866
Jun 2003
Catlettsburg, KY
I bought and installed a set of monroe sense-a-trac shocks to go on the rear. Will this affect the PRC system? An if so is there anything I can do to fix this? Huey
87 Turbo coupe, 5spd, full factory options, custom cerosion coated exhaust, Gillis valve, bent frame.
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
The only shocks/struts that ever worked with the PRC is the original factory Tokicos. Nothing else will work with the system and nothing can be done about it
Huey866
Jun 2003
Catlettsburg, KY
But I assume that the PRC computer will be throwing a code wont it? Huey
natmac3
Mar 2002
Aberdeen, MD
I have the same on my 88, and yes, the PRC light flashes all the time. But that's all...
--n8
1987tc
2birdsinthefalls887
Feb 2002
Beacon Falls,Ct.
Come on guys, all you have to do to prevent a code, is leave the actuators hooked up,hanging, not mounted to the shock. That's how my totaled 88 was, Sensatracs and acuators hanging. I hope this helps
88 Turbo Coupe,loaded 104,000,
88 Turbo Coupe,Fully loaded,
Nitro_X
Mar 2003
West Plains, MO, USA
Just remove the actuators, set the switch to firm and you have a solid green light. Last time I checked I don't have an intracranial link to the PRC computer, so if it throws a code, it doesn't seem cause any data collisions on my organic neural network. [Image: biggrin.gif]
87 TC, T-5 swap, billet quadrant / adj. cable, solid state IVR, fog light relay mod, PST suspension, KYB-AGX fronts, Gas-A-Just rears, K&N cone, billet alum BCV, med. red, 90's wing, polished snowflakes and centers, 195K+ Mi's., daily driver, feeding on ricers!
