teal95
Dec 2002
Grass Lake, MI
Where did it go? I've done it on 3 cars already but it's been a couple of years and I wanted to refresh my memory. I already screwed up once getting the a/c compressor apart...
Mainly I'm after the pedal installation since I won't get to swapping the actual trans for a couple of weeks. But since I have the dash loose to replace the heater core it makes the pedal swap a lot easier.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
vinnietbird
Jun 2007
Oklahoma
Remove the old pedal assembly, install the replacement. I'd pull the column first, and the driver seat to make room to work. Granted, my swap was for a cable operated clutch.
teal95
Dec 2002
Grass Lake, MI
I know the basics, I've done 3 TC and a couple of Mustangs. I was looking for a pictures to know which bolts to take off.
steve
3x '95 & '96 GT
Steve, I sent you a PM. These are all I can come up with. One is from Cool Cats
http://www.turbotbird.com/faqs/#Change%2...%205%20spd
Here is one for swapping a T5 behind a 5.0 on a Fox;
http://www.coolcats.net/tech/advanced/t5...rsion.html
teal95
Dec 2002
Grass Lake, MI
I'm pretty sure the article was here. I did find a reference to it (just saying it was in the tech articles) when I was searching yesterday but it's not there. I distinctly remember there being a picture that had been drawn over showing notching out of some of the holes. Since I had recently done the heater core when I did the first car I suggested to just pull the dash since it's fairly simple and it makes the pedal install a lot easier. And then you don't need to do any notching.
The coolcats one doesn't have pictures (at least that I can see).
steve
3x '95 & '96 GT
teal95
Dec 2002
Grass Lake, MI
I found the pictures I was looking for on Stinger's site. I'm not sure if that was what I referenced in the past but it has the pictures I remember.
steve
3x '95 & '96 GT
