miss ?
slacken00 Offline
i have a miss in my new tc i just bought, i just did a complete tune up, cone filter, fuel filter, plugs, wires, cap, rotor, and it still misses and hesitates, could this be because of a vacuum leak or something of that nature?
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
Ryan H Offline
Have you checked the timing? Fuel pressure?
Try pulling the codes and see what you get. Report back to us!
2300turbo Offline
i just had a similar problem with my 88 it was tfi pip problem
88 tc t3 auto 373.68 torino formal roof 302 c4 9 inch 3.50 posi locker
slacken00 Offline
sorry to ask this but what is the tfi pip? and how do i check that or fix it
Ryan H Offline
There is an article on the TFI/PIP in the tech section. Smile
slacken00 Offline
ok that says it runs fine after a minute or so mine runs fine for about a min. then it happens and it doesnt get any better
As Ryan said, pull run a complete code test (KOEO, CM, KOER) and see if anything shows up.
What tune up parts did you use? Motorcraft? What plugs did you use? These cars are very picky about the type / brand of tune up parts.
Xturbo coupeX Offline
Also make sure you gap the plugs correctly when you put them in. These car don't have a typical .044 gap, you have to gap them between .032-.036
If knowledge is power, you're a geo metro! (its an inside joke)
slacken00 Offline
i used motorcraft plugs and ford racing 8 mm wires, could it be the egr valve because the line that runs from the egr valve is broken?
Import Killer Offline
I dont know, I dont have an EGR on my car and it doesnt miss. Yea, make sure all the tune up parts are motorcraft and that you check timing and fuel pressure.
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
MOMO shift knob and boot
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
