MHD 7.5" diff?
GaryS#2 Offline
Anyone have the master housing dimension of the ford 7.5" diff?
I found the 8.8 but of course chilton and haynes don't put it in their specs.
Grocery Getter/Rice Cooker.
Gary, I don't relate to the dimensional term you are using. Can you put it in other words or do a quick diagram, and I'll see if it's in the service manual
GaryS#2 Offline
It's for setting the pinion depth.
It's the measurement from the center of the ring gear to the end of the pinion bearing.
Since Ford housings are CNC machined it should be the same number.
I'm either not finding it or not recognizing it.
The manual has torque specs, shim specs, runouts, backlash specs and all that but I don't see any dimension like what you described.
fordtech58 Offline
Ford doesn't publish that # anywhere I can find, even there specs books. They use a pinion depth set that has a gauge tube, gauge block and gauge disc. If I do the math and use 1/2 the gauge tube (centerline of ring gear) add gauge block and disc demensions the 8.8 # is 4.4199 (4.42) and the 7.5 # is 4.04.
I hope this helps, Rick B.
85 Elan 5.0 Mine since 86
85 TC 5spd. Wifes toy
86 TC 5spd. 1 owner Calif
86 TC 5spd. pc/rotted
88 TC 5spd pc/rotted
01 F150 Supercrew towrig
03 Taurus 3.0 24v 200hp. wifes new tire fryer wish that TC button was turbocharger not traction control
84 RZ350 Yamaha my ride
81 Ltd440 Kawasaki wifes
registry loves us !!!!!
80 Buick Dragcar 440ci Chevy [email protected] (was originally a turbo)
86 TC 5spd. 1 owner from California
07 Kawasaki ZX14 [email protected]
2012 ZX14 Drag bike [email protected] still tuning!!
05 Suzuki Hayabusa, [email protected] 1/4, 198.9604 2011 Loring
GaryS#2 Offline
That's close to what this guy says the 8.8 is so that must be what the 7.5 is.
http://www.superstallions.com/tech/drive...gears.html
Thanks guys.
