Melling HiV Oil Pump- will it clear OEM pan?
ridgeback Offline
I was going to replace my oil pump to a Hi-Volume Melling but noticed that they have a bigger gear which will cause the pump to reach further down in the pan. I am also reusing the original oil pickup tube,screen and pan and need to know if this will all still fit without any clearance issues or additional mods???
I saw some posts and profiles showing Hi- Volume pump installs but nothing about it being a problem free upgrade.
Ron
Ron
Black 87 TC, 2nd owner since [email protected], [email protected].
boosted chicken Offline
Why are you going to a HV pump? They are not necessary and can put excess stress on the aux/dizzy gears.
I haven't used either a HV or HP pump but I don't remember anyone mentioning having a problem with pickup location.
Personally, I believe the stock pump is very adequate. Also there is a lot of misleading info out there.
This is a good discussion and it brings out some incomplete understandings as well as some good grasp of the situation.
http://natomessageboard.com/ubbthreads.p...056&page=1
boosted chicken Wrote:Why are you going to a HV pump? They are not necessary and can put excess stress on the aux/dizzy gears.
^^^^^^THIS! The aux shaft / dist gear are a weak link on these engines. No need to stress them even more, especially what a standard volume / standard pressure is more than enough in the first place.
ridgeback Offline
I guess I only saw the posts regarding that HIGH PRESSURE pumps put excessive stress on the dizzy and that HIGH VOLUME pumps were on the fence of being neither beneficial or harmful.
Just thought it would be a good upgrade but if all agreed that both types (HP & HV) suck then so be it... stock it will stay.
I can save a few bucks with stock also, this Esslinger Billet Aux. $ Dizzy is a big nut!
Ron
BJL Offline
Moderator
had a high volume pump in my blue tc, that thing eat a dizzy gear every 6 months or so. engine up rebuilding the engine and using reg volume pump. never happened again.
Brian Larkin
88TC 330,000 miles
Slightly Modified
ridgeback Offline
Good to know.. Thanks! How long have you been on your latest Dizzy since the OEM oil pump?
Ron
BJL Offline
Moderator
i took it out of my blue car in 2004 and it sat on a stand for a few years then in 2007 i rebuilt it. My TC had 267k then, now has 315k.
Brian Larkin
88TC 330,000 miles
Slightly Modified
ridgeback Offline
sounds promising!
Did you replace just the distributor gear or the Aux shaft & Dist gear and new or used??
Ron
