Did not realize till recently when I saw a picture of the door panel that the TCs came with Map Pockets - mine had none.
What is the deal? Rare? No value? Break and are thrown away?
Never seen any for sale.
Any idea where I might buy a couple?
Thanks!
DennisWRaichart
Chuck W
Indpls, IN,USA
Year?
83 TC Clone, 87 Ranger 2.3T, 84 XR7, 80 XR7, 86 XR4 AND 88 Scorpio
tps87turbo
Feb 2003
Hammonton, NJ USA
Thanks!
They came on all 85-88 TC's.
Rare = No
No Value = ????
Break & are thrown away = Mostly
Seriously, most of them have broken off & the owners have thrown them away. You can post an ad in the wanted section & maybe someone has an extra set for sale. Good Luck.
Tony Sceia -
Chuck W
Indpls, IN,USA
There were various versions on the 83-84's as well. Some had the rigid pockets and the TC's XR-7s had the netted style.
BJL
Williamstown, New Jersey
i got tired of the map poickets fallign off constanly and the arm rests rattleing loose. iso i "borrowed permantly" the regualr door panesl the all one pice from my father 88 sport parts car, been in there since and i wil never take them out! and the map pocket ios bui;t into the panel
Brian J Larkin
1988 Non-Turbo Turbo Coupe
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
sequentail turn signals, 3g alt,afpr, k&n, 2 1/2in cold air intake.
custom 2in dual exhuast with SN95 SS tips. Tripcomputer, a/f and vac guages. color coded wheels and under going body work and repaint!
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull) DOH!!!!!
Brian Larkin
88TC 330,000 miles
Slightly Modified
philS
Bellingham, MA
Brian, did your new door panel match the color of your turbo bird? I've been thinking about doing this, just cause I get so sick of r/r all that stuff on the door. Now I leave it off [Image: biggrin.gif] Would be nice to have a simpler door panel.
Click here to beat a ricer.
