Manual rack?
Harvs Offline
Would it be a pain to steer a manual rack, what are the pros and cons of it, and where could i get one?
philS Offline
Pros: more precise feel, less mechanicals to go wrong (p/s pump, p/s lines, p/s fluid, etc)
Cons: harder to steer at slow speeds, "palming it" is not an option in parking lots!
There's always the junkyard, but I wouldn't bother with a used rack, unless you rebuild it. Autozone carries rebuilt racks. Jegs carries the Flaming River manual rack, but they are pricey (~$250).
86 TC, 73 Mini, 72 Mini Van project (w/ LS-1 motor)
Click here to beat a ricer.
rich Offline
I was thinking of doing this too, but there is something that I recall being different between the two that makes me think it needs an adapter or something? Is that right?
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
philS Offline
You'll need a Fox rack.
The only thing I'm not sure about is the outer tie rod ends ... if those are specific to the manual racks.
Dan E Offline
Not sure why but something about that statement gets me...well ummm...hot. [Image: biggrin.gif]
Dan Eaves
philS Offline
Dan,
so lemme guess ... you like it when people give you the "nice rack!"
