turbotbirdguy79
Feb 2004
lockport,ill,united states
I bought a set of nuts for turbo to manifold since mine are getting rounded out.They dont seem to fit though.The size is m10x1.50,is this the right size?If not what size are they?I did a search on here and TF but really found nothing.Thanks in advance!
That is the right size. Not sure on this but if they are one of the special types, like self locking or something like that, they may be hard to get started.
cnpowell
Nottingham, MD
Those are the parts I used and they did fit a bit loose. I guess that is for heat expansion. I got them from this website: www.atpturbo.com
Carl
Carl
turbotbirdguy79
Feb 2004
Thanks guys
Ryan H
Oct 2004
Panama City, FL
I did the same thing. You have the right size. Mine felt too snug. I believe this is attributed to expansion/contractions from the heat as well as rust. Just clean the studs off really good, lube them and install the nuts. Make sure you use at least grade 10.
