plstktnkr2
Apr 2007
sharpsburg MD
I have a car that runs and drives, but no power windows,locks,sunroof,mirrors,seats. is there maybe a root area, or common area that I can look in to minimize troubleshooting time?
rick
All Ford all the time, 4 stangs 1 lincoln 'vert and 1 turbo 'bird
UglyBird85
Jan 2009
Norfolk, Va
these cars are an electrical failure. I honestly dont even know where to tell you to start. pete will probably email you some good wiring diagrams. He did it for me but it might as well be in chinese.(I dont do electricity)
I gave up and just took the 185000 mile motor and turbo out of my "electrical nightmare" 85TC and put it in a 87TC with a blown motor. Probably a lot less of a headache and cheaper lol
Sorry I can't help though...
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
junkedturbo
Apr 2008
Batavia IL
If your fuses are all good I'd take a look at the junction block, should be under the battery case. You'll see 7 wires all connected together with Fords truly inline fuses, this will be the heart of your electrical system were battery, alt., etc. are all connected.
If you have that many things out the problem is most likely there OR you have some bad grounds, don't know the true problem till you start digging into it.
Pete D and Jeff K will be about your biggest help here with this
You cant own one of these care without owning the EVTM / wiring diagrams. I am at work, and dont have my diagrams with me, but with all that stuff out, I would guess a blown / corroded fuse link like junkedturbo suggests.
Check your email for charge power diagrams
plstktnkr2
Apr 2007
sharpsburg MD
I now have vols A and B of the '88 manual set plus EVTM so I will keep you all posted on my findings.
Pete D: thankx
plstktnkr2
Apr 2007
sharpsburg MD
ok guys update: 3 missing curcuit breakers were missing, dash was torn apart, put in all 3 breakers and assembled dash. car works perfectly
thanks guys
rick
