Mach One Chin Spoiler
BJL Offline
Moderator
finally got my new bumper finished and Mach one chin spoiler on this past weekend
https://imgur.com/Pm0J9Jz
https://imgur.com/boE5Mtn
https://imgur.com/60JEguv
Brian Larkin
88TC 330,000 miles
Slightly Modified
Mikey97D and Pjl3118 like this post
I love it! If only mine had a chin to mount one to I would be doing this as well, unfortunately some previous owner cut the front of my lower bumper. Was it easy to mount?
Looks great, Brian!!!!
ThorJrTurbo Offline
LOOKS AWESOME!!!!
Turbo Coupe For Life
1987 Turbo Coupe, Black, 5 Speed, K&N, RR cam
BJL Offline
Moderator
yes easy to mount, used some the holes the old one used and added a few more spots that are nut and bolted.
i had the bumper off the car.
i had to trim about 4 inches off each end to fit the bumper, but not a big deal.
Brian Larkin
88TC 330,000 miles
Slightly Modified
vegas_ss Offline
What year mach 1 spoiler fits?
gtbird Offline
(07-10-2020, 05:52 PM)vegas_ss Wrote: What year mach 1 spoiler fits?
The Mach 1’s were made in 03 & 04.
Here’s one place to buy one: https://lmr.com/item/SVE-17626M1/1999-04...in-Spoiler
1988 T/C Silver with red interior, fully loaded except for leather. 5 lug conversion with 97 Cobra wheels, Cobra 13" brakes up front, Mustang brakes out back, Koni adjustable shocks and struts, NOS Koni lowering springs . Maximum Motorsports control arms and caster/camber plates, subframe connectors.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing....time for a new chapter in my life.
BradM Offline
This looks like it would block the factory air dam and effect cooling. Any issues?
gtbird Offline
You remove the flat factory one and this one mounts in its place and it does not effect the cooling.
BradM Offline
I ordered one from LMR and I love it. Drill it out to match the existing screw holes and use 3-4 of the supplied plastic push pin on each end (and yes, you'll cut off 3-4 inches from end). I found that making one relief cut on each side helps the corners align better. I don't know how someone figured out this fit but I love it. I added a picture of the '03-'04 Mach 1 for reference.
Attached Files Image(s)
Mikey97D and foxhound1972 like this post
